Found a really good deal on an 06 F250
Old Dec 13, 2010 | 02:45 PM
Jason84's Avatar
Default Found a really good deal on an 06 F250
I am just curious what the known problems are for the 6.0 diesel and how good of a motor are they? what are the fixes for it? and how many miles will these engines go?
Old Dec 13, 2010 | 06:25 PM
newman's Avatar
What is a "good deal"? These engine can be a PIA if not maintained properly.
Old Dec 13, 2010 | 06:50 PM
doda's Avatar
I can say they are strong. I pull a fifth wheel 12000 lbs. dry weight any where I want to go. I have a 04 f350 auto 6.0l and do it in a hurry! I have had EGR problems and not wanting to start in real cold weather. I get 13 mpg pulling the trailer. uhhh It's pretty to look at!
Old Dec 13, 2010 | 07:57 PM
ranger518's Avatar
Mine has lots of power and would not have anything else but you really need to keep up propper maintance on them.
Old Dec 14, 2010 | 07:32 AM
Mdub707's Avatar
Major issues are emissions related (EGR valve and cooler)... the fix is a full delete kit, which can be done by yourself for almost pennies or you can buy kits anywhere from $200-$600. The price difference comes from the different style kits.
Another major issue is headgaskets. Our head design kind of stinks. They only use 4 bolts per cylinder to clamp the head to the block. They're known to fail even on stock trucks, but a tuned truck will be far more likely. Fix is ARP headstuds, new gaskets and having the heads decked/pressure checked at a machine shop. This can be done with the cab on in your drive way if you wish, but is easier with the cab off on a lift.
The oil cooler is the main source of all these problems and often overlooked. Casting sand from the block passes through the coolant passages and clogs the oil cooler. The oil cooler is in charge of regulating the temps between oil and coolant. If it clogs up it can't do that and you will overheat the EGR cooler and cause it to fail... The fix is an oil cooler rebuild kit and a coolant filter setup.
Do it right and do it once (seems like I say that a lot lately). Those mods, a good custom tune with an SCT programmer, a good turbo back exhaust and some gauges and you'll have a reliable 400+ rwhp truck.
Old Dec 14, 2010 | 06:45 PM
newman's Avatar
Also remember oil is the life blood of your engine. The injectors, bearings, turbo, and pistons don't like hot oil.
jake_evans
Feb 23, 2015 08:08 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
Hardcorefx4
Oct 6, 2014 07:47 PM
KOMONER
Oct 6, 2014 01:14 PM
