93 7.3 cutting off
Old Dec 13, 2010 | 11:11 AM
suttonw's Avatar
Default 93 7.3 cutting off
Hi guys this is my first post, my brother inlaw has a 93 f 350 that doesn't get run much. It has developed a probem, it starts fine but whenever he slows down and the engine cuts off, it restarts fine and will run fine until he slows down again, any suggestions.
Old Dec 13, 2010 | 03:06 PM
DieselCrawler's Avatar
what is his idle rpm? also stick or manual?
Old Dec 13, 2010 | 03:09 PM
Bigred7.3's Avatar
sounds to me like the timing on the ip is off, i had a truck that did the exact same thing. there are a few people on here that can deffinetly help you on how to adjust the timing correctly if that is indeed the problem.
Old Dec 13, 2010 | 06:48 PM
suttonw's Avatar
it has a stick and idle seems normal (700-800), would like to learn more on the ip timing
Old Dec 13, 2010 | 07:24 PM
to time the pump u will need to either find someone with a diesel timing meter or a shop with one. where are u located?
does it start easy after sitting overnight?
Old Dec 14, 2010 | 07:57 AM
suttonw's Avatar
I am in eastern NC and the truck starts fine at any time, even after it shuts off while driving
Old Dec 14, 2010 | 09:55 AM
css89's Avatar
Default pump shut off
It wouldn't be something simple like a bad electrical connection to ip solinoid would it when engine goes to idle the engine viberation changes and pump solinoid shorts out or something like that.
just a thought
Old Dec 14, 2010 | 10:59 AM
suttonw's Avatar
good idea i will check it out. thanks
Browe347
Dec 11, 2016 02:59 PM
xcursion88
Apr 6, 2015 06:54 PM
racinfast002
For Sale
Jan 7, 2015 12:46 PM
Altonlee
9
Oct 8, 2014 02:31 PM
Browe347
Sep 30, 2014 11:35 PM
