wont start,,2002 cummins
Old Dec 13, 2010 | 10:26 AM
texyug's Avatar
Default wont start,,2002 cummins
will 2002 cummins start with wd-40
Old Dec 13, 2010 | 11:28 AM
jwh's Avatar
jwh
Why will it not start does it turn over?
Old Dec 13, 2010 | 11:33 AM
texyug's Avatar
well i walk to the autozone and got starter fluid for diesel and gas,,it started right up,,it was 27 degrees this morning,,thanks for the reply
Guy Cardwell
Old Dec 13, 2010 | 06:16 PM
Do not start it with starting fluid. Dangerous due to the grid heaters.
Old Dec 13, 2010 | 06:26 PM
prison's Avatar
it shouldn't be used anyway because everybody uses it completely wrong and on high compression engines ether or starting fluid lowers that compression pretty easy
Old Dec 15, 2010 | 05:52 AM
Blacksmoke Bulldog's Avatar
Lift pump may be getting weak. Need to code truck, maybe it will send you in the right direction
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
