I have no clue whats wrong
I have a 03 6.0 powerstroke and I have a stack with sct canned tunes. When I put the canned performance or street tune on my exhaust starts to break up around 3000 rpms. I have no clue what would be causing this but any ideas would be very apreciated.
Thanks in advance
Anthony Susi
Thanks in advance
Anthony Susi
What do you mean "break up?" I have straight pipe into a stack and around 3,000 is where my truck loses the turbo sounds and starts SCREAMING
... Its how 6.0's sound on straight pipe... If its that sound your describing than no worries... if its something else try and describe what you mean by "break up" a little better so we can try and help!
Get a fuel pressure gauge and the correct size fittings to hook it up to your fuel filter housing. If you look at the housing, you'll see a couple empty ports that just have "caps" in them. Take one out and hook the gauge up there. Should hold 55psi all the way through. (50-60 is ok). 45 and lower is BAD.
gumborancher
Apr 24, 2015 01:25 PM
nelly559
Feb 2, 2015 08:19 AM
