SDX injectors
Old Dec 12, 2010 | 06:08 PM
cummins_guy's Avatar
Default SDX injectors
just wanted to throw a big thank you to Brice at BBD and SDX for the great injectors.
I also wanted to point out that the injectors also helped with the truck shutting off when I shut turn the key to shut it down; when I first bought the truck, there was this rattle of the engine at idle and would smooth out when accelerating, so I replaced the injection pump (14mm head) it still did the same thing but would shut off when I turned the key, then after about 3 months, it started the same thing, not shutting off when I turned the key, so I just said F@#$ it, and buy a set of injectors, well today I put them in and the nasty rattle went away and it will shut off when I tur the key off, I never thought that the injectors would cause this even after the injectors that I had in it, were checked out and nothing came back, that when I changed them, it would clear up all my problems.
I bought the 5 x 14 , they are a little smokey, but when the hwic/hx40 turbo kicks in, they clrear right up.
I know that I dont have my upgrades on line, here there are
14mm pump, isb oil pump, 5x14 injectors, h1c/hx40 turbo, euro 2 camshaft, 3911400 marine pistons, 60lbs springs, ported head by me,DENNY T 2 FUEL PIN, and soon to come, seat inserts.
Again, Thank you Brice @ BBD PERFORMANCE and SDX
Old Dec 12, 2010 | 08:15 PM
JBradley500's Avatar
Im glad the SDX stuff is working well in the 1st gen scene too. Maybe the prices from the other places will get back to reality. Some of the aftermarket injectors arent that reputable yet you wouldnt know that by the price tag on them.
Old Dec 12, 2010 | 11:00 PM
kieron_kohlmann's Avatar
I love my SDX injectors! 5x14 are amazing! somehow i still manage 22mpg in town provided i can keep my foot out of it.
Old Dec 13, 2010 | 07:13 AM
450sandridr's Avatar
how much did the sticks run u compared to other companys
Old Dec 24, 2010 | 09:25 PM
hiboy_76's Avatar
i'm wanting to get injectors, but i dont know what size i should get. I dont know whether i should get the 5x16s or 5x18s. I have a S300 i'm going to put a 62mm wheel on and i might go twins in the future. what do you guys think?
Old Dec 24, 2010 | 10:52 PM
big bad diesel 416's Avatar
Site Sponsor
Your welcome Mike thanks for the kind words!
Correct some company's are proud of there name and charge 700 a set and other company's just sell pure **** and sell for 400 a set but the fellas at SDX have worked out a good thing there prices awesome and there making the best injectors on the market
Shoot me a PM and I can tell you
I have sold alot of 5X0.14's (140HP) to guys running the 62MM chargers and they love them I would run no bigger than 5X0.16 IMO
- Brice
Old Dec 25, 2010 | 09:06 AM
hiboy_76's Avatar
thanks BBD, hey whats that VE pump tune on your website?
Old Dec 25, 2010 | 10:34 AM
Site Sponsor
Just our little something special
Old Dec 27, 2010 | 07:35 PM
jarheadrichard's Avatar
OK...first post here so here it is....
My 93 D250 3/4 ton is semi stock at the moment but I have a new job running loads of machine parts state wide and interstate...some heavy to be sure.
I have inquired in Missouri about injectors for the 12 valve and mixed confusing responses.
What I need to know is... given the stock rotary pump, what size injectors are recommended for this engine and the use. Trans is auto.
I do have a KN air filter and am going to get 4" pipes put on. Have 3 1/2" coming out of the turbo which is also stock.
Any other "step by step upgrade suggestions" would be appreciated...including rotary pump if anyone things that is a factor to address later.
I know I am going to need the extra power with the hopes of maintaining reasonable milage.
Thanks ahead of time for any advice.
Old Dec 27, 2010 | 08:31 PM
RSWORDS's Avatar
You want to tow heavy alot and stay reliable?
Keep it stock and well tuned. Adjust the valves, check and make sure all the injectors are popping off at the correct pressure, check you fuel supply pressure and give the whole truck a good once over.
