oh where to start
Old Dec 11, 2010 | 02:04 PM
alwazjeepin98's Avatar
Question oh where to start
have 01 cummins ho i bought this truck urber cheap without a turbo and hearing it run. got turbo for it new lines fluids ect... started first crank. mind you this truck sat in feild for almost 2 years. found out had bad clutch so i got and oem and install. installed new fass pump and got rid of in tank pump via draw straw. anyways i have a millioin codes 1693 0203 0237 1689 0562 0382 0380 0215... when truck starts it kinda spits a little when reving after a few mins it dont weanna rev past 1500 rpm or so it will however rev up on occasion. umm also sometimes it doesnt wanna start. if i let sit for 20 mins or so it start right up.. any body got anything for me?
Old Dec 11, 2010 | 02:32 PM
Farmboy 2.0's Avatar
Sounds like a vp issue if it sat for 2 years the fuel in it id say the vp is bad
Old Dec 11, 2010 | 03:40 PM
turbo20psi's Avatar
Check the relay under the hood "Fuel pump Relay" Drivers side
When this relay is missing or broken the VP44 doesn't energize nor pump fuel. It allows you to do the cranking test. But it also sets a P1689 and CEL light. So for all of you that have a P1689 error code present check your fuel pump relay first by trading with another relay!
Check this first, lift pump second, and replace VP44 third.You can have the VP44 check bench tested at a Bosch dealer.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
