6.2 starting problem
Old Dec 11, 2010 | 10:54 AM
joey's Avatar
Default 6.2 starting problem
I have a 6.2 1 ton. The other day the guys were running down the road and they said it sputtered then died. I have good fuel at the filter and to the pump but very little, if any out the lines. Could the pump have gone out and still be putting out fuel or is it not the pump and possible something else. thanks for any help
Old Dec 11, 2010 | 11:10 AM
Crazy's Avatar
maybe air in the fuel system put clear fuel line on the from return see if have any air bubbles and check the return line see they leaking
well if you are talking about little fuel come out the injector line you won't see high pressure once you crack the line you release the pressure
Old Dec 11, 2010 | 01:02 PM
joey's Avatar
ok that makes scense but shouldnt fuel like spray out when i crack it not just dribble.
Old Dec 11, 2010 | 01:16 PM
Crazy's Avatar
nope it won't spray out it just dribbles
Old Dec 11, 2010 | 01:26 PM
joey's Avatar
ok so use the clear hose and make sure i have a steady return of diesel not one with a bunch of bubbles.
Old Dec 11, 2010 | 01:30 PM
Crazy's Avatar
right look at the return lines in between injectors make sure they are dry
Old Dec 11, 2010 | 01:33 PM
joey's Avatar
ok so if they are leaking that will let air back into the system. Also if you run the truck on the right tank it has no power and will idle up and down like its starving for fuel. on the left tank it runs fine. so if the returns arent leaking and it has good return flow, could there be any other reason for it not to start.
Old Dec 11, 2010 | 01:37 PM
Crazy's Avatar
ok didn't know you had 2 tanks right tank may have clog sock in the tank or lines leaking some where between tanks all it take is a pin hole in the line
Old Dec 11, 2010 | 07:50 PM
joey's Avatar
ok i will post back if i find anything out. Thankyou man
ok found the problem i had an air leak. I went and bought clear hose and plumed that in place of the black hose so i could see the air bubbles. It turns out i had a dry rotted fuel line. Once i used the clear hose i could see the bubbles.
Old Dec 11, 2010 | 09:19 PM
Crazy's Avatar
glad you found the problem 99% of the time with older 6.2 is fuel problem
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
Jmohr52
Nov 2, 2014 08:55 PM
