12v to 24v head?
Old Dec 10, 2010 | 10:34 PM
wyodiesel92's Avatar
Default 12v to 24v head?
I've been toying with the idea of p pumping my 24v and that got me thinking could I just get a 12v and get a 24v head to put on it? And then just get the injector lines and injectors for what would be a swap on a 24v for a p pump? I kinda want to keep my 24v vped and thought about getting a 12 and swapping heads and doing the injectors and lines like I would for swapping my vp to p pump
Old Dec 10, 2010 | 10:40 PM
prison's Avatar
yeah its been done. but that was a confusing post
Old Dec 11, 2010 | 01:45 AM
blazier18's Avatar
ill trade u a 12 valve head for ur 24 valve. got all redone 12k miles ago on the clock
Old Dec 11, 2010 | 09:58 AM
turbostang7's Avatar
to put a 24 valve head on a 12 valve you must also change the pistons to 24 valve pistons. the spray pattern is way differnet and needs a different bowl in the piston.
Old Dec 11, 2010 | 10:07 AM
RAW's Avatar
RAW
P-Pumped 24V seems to be the big power maker. The P7100 can deliver a ton of fuel, and a 24V head can flow more air and has centered injectors.
Old Dec 11, 2010 | 11:30 AM
94 12valve's Avatar
you have a PM
Old Dec 12, 2010 | 09:44 PM
Sorry for the confusing post, I was pretty close to falling asleep and then that came to mind. Guess it'd be easier just to p pump a 24v
Old Dec 12, 2010 | 09:47 PM
prison's Avatar
i thought you could just toss the heads on a 12er. turbostang are you positive?
Old Dec 12, 2010 | 10:11 PM
yeah the injectors on the 24 valve are directly over the piston, where the 12 valves come in more from the side, therefore the bowls are shaped differently for the injector angles. i will try to find some pics for you guys
12 valve
http://i213.photobucket.com/albums/cc109/countryhunley/Cummins%20Build/pistons.jpg
24 valve
https://www.dieselbombers.com/5-9l-2...-build-up.html
Last edited by turbostang7; Dec 12, 2010 at 10:11 PM. Reason: Automerged Doublepost
Old Dec 13, 2010 | 02:34 AM
blazier18's Avatar
nevermind no trading tony and dave changed my mind
Dayt the great
Aug 16, 2015 07:42 PM
Dayt the great
Jul 22, 2015 01:23 PM
gd1996
For Sale
May 15, 2015 09:42 AM
Tory4
For Sale
Feb 1, 2015 08:33 PM
Adam65
Jan 9, 2015 11:50 PM
