HELP wont start!!!!
Old Dec 10, 2010 | 06:44 PM
shepler75's Avatar
Sad HELP wont start!!!!
Hi im new to this site and new diesel owner here is my problem went out and started my truck thursday was very cold out 15 deg. fired up not pluged in it started to sputter so i jumped inside to bump up the idle and it died wont start back up cranked and cranked so i pluged the heater in overnite and put battery on charge went out today about 39 deg out cranked and cranked turns over very very fast? still no hit or any sign of starting no smoke so i cracked the air breather open sprayed just a squirt of ether and it acted like it wanted to start i give up i dont know alot about diesels please any help would be grateful thxs
Old Dec 10, 2010 | 06:49 PM
blazier18's Avatar
crack your number 1 injector line on ur injector and crank ur truck and see if fuel is comin out. if theres a good bit comin out tighten it back down. id check them all just in case. next id check ur fuel filter could have all sorts of junk in there. if both of those are not it check ur lift pump. dont use ether get a rag soak it in gas well dont soak it but get it wet and put over ur air filter or wd40
Old Dec 10, 2010 | 07:07 PM
shepler75's Avatar
thanks will give it a try
Old Dec 10, 2010 | 07:08 PM
blazier18's Avatar
sounds good man and welcome here let me know if it helps
Old Dec 11, 2010 | 09:36 PM
shepler75's Avatar
Default fixed!!!!!!!!!!!!!!!!
thanks blazier18 opening the lines worked must have gotten air in them from cold or something but anyway thanks for you help
Old Dec 13, 2010 | 02:51 AM
blazier18's Avatar
hey it aint no problem i learned it from here so did u! good job brother
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
