2004.5 dodge cummins?
Old Dec 10, 2010 | 06:01 PM
98dodgecummins's Avatar
Default 2004.5 dodge cummins?
Ok i might be getting a 2004.5 dodge cummins is their anything i need to look out for on these trucks. the guy said the lift pump went out a couple days ago and h e put a new one in. Would letting the lift pump on these truck go out hurt the injection pump or not. its a 6 speed, 4 wheel drive. Thank You.
Old Dec 10, 2010 | 09:55 PM
steved's Avatar
Did he put the pump in the tank?
The failed lift pump most likely didn't hurt anything.
Old Dec 10, 2010 | 10:23 PM
No i think it is just a regular pump he put back on it.
Old Dec 11, 2010 | 06:21 AM
83cucv1028's Avatar
i'm on my third lift pump in my 2004.5, the dealership upgraded to the in tank pump on the second one, and i put in the third. injection pump should be fine as long as he didn't run it for a long time without the lift pump.
Old Dec 11, 2010 | 07:33 AM
whats the deal with the factory lift pumps? whats else should i look out for on these trucks? is their any bad problems or not ? the guy says he never has put a chip on it.
Old Dec 11, 2010 | 11:54 AM
83cucv1028's Avatar
jack up the front end and check the bearings in the front hubs(grab the tire on the top and bottom and check for play). i'm on the third set of those too. i do have 240,000 miles on mine though. check the pulley on the tensioner also, it is plastic and they wear out around 120,000 miles.
Old Dec 11, 2010 | 03:51 PM
yeah one thing also on this truck it has a 4 inch lift and 35 inch tires. thats probably not to good.
Old Dec 12, 2010 | 12:25 AM
steved's Avatar
I just drove 2000 miles on a failed FASS...truck sits with over 235k. The truck runs fine and the failed pump did not seem to cause any performance issues. So how long is too long is a good question...
Your lift and bigger tires will accel the wear on suspension and bearing components...
Old Dec 12, 2010 | 05:00 PM
im pretty sure when it went out he changed it pretty quick.
What about injectors i heard there was some kind of problem with the injectors sometimes.
Last edited by 98dodgecummins; Dec 12, 2010 at 05:00 PM. Reason: Automerged Doublepost
Old Dec 15, 2010 | 08:30 AM
any thing else to look for .
