my gauge cluster is freakin out in my 98
there is something serriously wrong with my gauge cluster speedo rarley works and even gets stuck sometimes rpm works most of the time but goes up and down alot oil presure goes off sometimes but comes back on and abs e-brake and seatbelt lights are on at all times and wait to start and check engine come on usualy come on when rpms are freakin out and also my lights flicker when things go crazy but the truck dives perfect abs and e-brake fuction perfectly. here is what i think the problems may be the batteries are 2005s but they start the truck fine even in the cold and when its been siting, posibly a bad ground, and the vss, maybe the gauge cluster itself tell me what you guys think
Voltage regular=yes Whatever fp gauge you put on a 12v will jump. Just because the lift pump is ran off of the cam so it will not get a good reading. What you need to do is get snubber and a isolater for it, to help calm down the gauge because where its moving all the time itll kill the gauge evently
I doubt it has anything to do with the batteries or the volage regulator. But, as for the voltage regulator in the PCM, it's bypassible.
http://www.dieseltruckresource.com/f...n&onlynewfaq=1
well i just hate it when i fill up and my gauge jumps up and down and wont stay in one place then after i turn the truck off it will quit actin up when i start it until i stop a redlight
