7.3 Turbo Low Idle
Old Dec 10, 2010 | 03:27 PM
clay37355's Avatar
Default 7.3 Turbo Low Idle
I have a 92 F250 7.3 Turbo auto. The truck has been doing great. One day I was driving and let off the pedal before a small curve and it died. I turned the key and it started right back up , But now to keep it running I have to keep a little pressure on the pedal or it will idle down real low. If i snap the throttle it will pick up normal , but come all the way down and die. It will idle, barely if i ease the throttle down, I did change the filter , but no change.Any ideas??
Old Dec 10, 2010 | 04:38 PM
DieselCrawler's Avatar
is it idling lower than normal? the adjustment is on the side of injection pump. pass side. looks like s adjustment that is on a carb. just turn screw in more to raise idle.
Old Dec 10, 2010 | 04:57 PM
clay37355's Avatar
Yes, it is idling lower than normal. I saw the idle adjustment screw and will probably adjust that to bring it back up, but was wondering why all of a sudden the change in idle rpm? I did check the adjuster to see if it was loose and it wasn't.
Old Dec 10, 2010 | 05:21 PM
not quite sure. maybe high idle solonoid was stuck and not letting the lever go all the way down.
soco
Jul 27, 2015 06:06 PM
fivo2fst4u
Jul 2, 2015 06:20 PM
JSATCT860
10
Jun 26, 2015 12:13 AM
robbyS
Apr 16, 2015 02:22 PM
tumble72
8
Nov 27, 2014 10:31 PM
