blowin oil quick need help
Old Dec 10, 2010 | 05:10 PM
luke46's Avatar
Default blowin oil quick need help
got the jump on a 96 4x4 ext cab 5 speed truck for 3500 just started puking some oil out the breather is this a simple fix or is it bad still runs good with good power. I need to know pretty quick so I can pick this up or not thanks everybody.
Is it pretty much a broken piston ring or can something else cause this I can check.
Old Dec 10, 2010 | 05:44 PM
blazier18's Avatar
the breather?
Old Dec 10, 2010 | 08:20 PM
Dirt_Diver's Avatar
Need more info man! Oil is leaking and comming out of the breather? My guess is, you got a blown turbo seal.
Old Dec 10, 2010 | 08:43 PM
blazier18's Avatar
the breather as in intake?
Old Dec 10, 2010 | 09:36 PM
Dirt_Diver's Avatar
Air filter
Old Dec 11, 2010 | 01:17 AM
GuyWithA24Valve's Avatar
Since you have 365,000 on the truck and you have injectors and an ottomind, it could be a broken piston ring or rings. Usually it'll blow it out of the breather, the dipstick tube, or both. We had a Cat 627B that the front engine was blowing oil out the dipstick and breather because of a broken piston ring. It still felt like it had plenty of power but once we rebuilt it, it was a world of difference. But then we had an NT855 cummins that destroyed ALL of the piston rings but it didn't blow oil out the breather, just had more blow by than normal
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
