edge jammer injectors? any good?
what brand would be best and what do u mean they run dirty? do you mean they smoke alot?
and is it a good move to get injectors before lift pump or the other way around?
Yes my 75's almost rolled more coal than my 6x18's i have now and they ran just as hot becuase of the crappy 8 hole design and spray pattern. Id save your money and wait for a good set of industrial injections 85's or something along those lines.
GET A GOOD LIFT FIRST! VP's have fuel supply issues even stock.... look into a raptor 150 or a AirDog150 before you do any mods and get a fuel pressure gauge if you dont have one yet
with the raptor 150 you get big lines and to tell if you have a external lift pump look below and to the right of the fuel filter and if there is a little pump on the side of the block its external if there is nothing it would be a in tank. And you dont have to run a draw straw with the raptor 150 it hooks right to the factory hook up
it will not have an in tank pump unless it has been replaced by a dealer in the past and the did the in tank fix so to speak. and it all depends on what you want out of the truck. if you want big power id go with a draw straw or a sump kit and big lines to feed the max fuel. there are alot of good brands of injectors...industrial injec, sdx, ddp, luke at diesel dogs has big dawg injectors ive heard good things about.
