how to wire in lift pump
Old Dec 9, 2010 | 09:30 PM
12valvecory's Avatar
Default how to wire in lift pump
Im not sure where to put this but i have a 2001 half ton that has a 91 cummins in it so im trying to find out how i should wire the lift pump in the tank to send fuel to my lift pump on the cummins. It just takes 12v to turn it on but i dont want to burn the pump up. so any help would be a big help to me just to know where to tie it in.
Old Dec 9, 2010 | 09:42 PM
D-LUX's Avatar
there should be a stock relay within the existing system that ran the original fuel pump...i would think you could use that to run the lift pump
Old Dec 10, 2010 | 06:15 PM
Yes but alot of th wiring is hacked from the change and thE computer is gone so there is nothing to tell it to come on
Old Dec 12, 2010 | 03:03 AM
D-LUX's Avatar
so then through the fuse block, find a circut that only has power with the key on...run the pump off a relay with power off the battery, then use that key on circut to activate the relay...problem solved....
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
