hard start
Old Dec 9, 2010 | 06:10 PM
broken7.3's Avatar
Default hard start
1991 f250 starts and runs fine turn it off wait 30 minutes it starts runs about 30 secounds rough then shuts off wont start wait several hrs and it will start and run great
Old Dec 9, 2010 | 06:31 PM
DieselCrawler's Avatar
does it fire up ok when the motor is cold, then not start when hot?
if so, i am gona say your injection pump is shot. the alumium pump expands when hot, throwing the tolorances out the door and causing the hard start/no run issue.
Old Dec 10, 2010 | 04:39 PM
broken7.3's Avatar
it doesny real matter yesterday ran for about 4 hrs shut off for maybe 10 min.started fine waites about an hour started fine about 1/2 hr later started ran rough and shut off about 2 hrs later started fine
Old Dec 10, 2010 | 04:42 PM
possibly air intrusion into fuel system. do u have ANY fuel leaks? return lines on top of motor all dry? what condition are they in?
Old Dec 11, 2010 | 07:15 AM
broken7.3's Avatar
yes return lines dry seems like air but cant figure where its coming from
also ty for your help
Old Dec 11, 2010 | 08:23 AM
do u have dual tanks?
Old Dec 11, 2010 | 12:10 PM
broken7.3's Avatar
yes i do have dual tanks
Old Dec 11, 2010 | 01:29 PM
has the selector valve ever ben touched? sometimes they go bad and can get stuck between tanks and sucks air. but that is a long shot. i have no clue, that last one is a major guess.
Old Dec 12, 2010 | 08:02 AM
broken7.3's Avatar
thanks for your help i will keep searching anymore ideas pls lrt me know TY
Old Dec 13, 2010 | 10:23 PM
Sycostang67's Avatar
Check the hard fuel line running under the motor along the cross member, they can rub through sometimes. The fuel pump also has a weep hole that will leak if your diaphragm tears.
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
