making 87 f350 into 4x4
Old Dec 9, 2010 | 11:19 AM
css89's Avatar
Default making 87 f350 into 4x4
I have engine out of my crewcab f350 and am in process of putting in 6.9 from a 3/4 ton 4 wheel drive truck. So seeing I have a f250 front end on my donner truck what would I have to change to make it work with my f350 brake rotor hubs etc:? so I can use 1 ton wheels
I will use tranny and transfer case from f250 and will modify rear drive shaft
Last edited by css89; Dec 9, 2010 at 11:22 AM. Reason: I should add I will use 4 speed and transfer case from f250
Old Dec 9, 2010 | 11:32 AM
DieselCrawler's Avatar
possibly, but lots of work. i am assuming the f350 is dually? if so, no real way to make the f250 ttb axle into a dually without aftermarket spacers. f350 have d60 front axles, f250 have either d44hd or d50. matters on age.
Old Dec 12, 2010 | 12:54 PM
css89's Avatar
Default 350 to 4x4
Yepp I thought that it would be to easy.
Old Dec 30, 2010 | 08:06 PM
rab475's Avatar
I think you can use the adapters from a late model dodge 4x4 dually, the late model ford has a bolt on adapter to use the budd wheeels but it is the wrong pattern I think the dodge is the same design and the botl pattern is the same.
smbenoit_79
May 19, 2015 01:32 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
2FordStrokers
Jan 11, 2015 09:40 PM
fatography
Oct 23, 2014 08:23 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
