Odometer not working correctly
Old Dec 9, 2010 | 09:06 AM
alfxc08's Avatar
Default Odometer not working correctly
My odometer is spinning very slowly, I'd say it spins a tenth of a mile for every mile I drive. Does anyone know if this can be fixed or should I just buy a new instrument cluster. I've heard that the odometer cable might just need to be lubricated. Any info will help. Thanks!
Old Dec 9, 2010 | 10:16 AM
Crazy's Avatar
is this on your 98 if it is there not a cable it computer run
Old Dec 9, 2010 | 03:47 PM
alfxc08's Avatar
Yes, it is the odometer on my 98. Any suggestions on what I could do to fix it or do I just need to change the instrument cluster? Thanks.
Old Dec 9, 2010 | 04:35 PM
Crazy's Avatar
check all the plugs at trans and clean them you may want check and clean all the grounds
There are 2 vehicle speed sensor know as VSS on the side trans not sure they run speed O but do control shifts
and this info is on auto trans and will try find more on it for
Old Dec 9, 2010 | 04:53 PM
Crazy's Avatar
OK here what found out there a (Vehicle Speed Sensor Buffer) VSSB that mounted to bottom off the computer that calibrates speed-O and it is behind the glove box
here pic of it
Old Dec 10, 2010 | 01:03 PM
alfxc08's Avatar
Awesome info, thanks alot guys. I'll check it out as soon as I get home. (I'm on travel for work until next week) Thanks again, I'll let you know how it turns out.
JPT18
Mar 6, 2016 11:20 AM
Mar 25, 2015 01:50 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
hemiheath
Oct 15, 2014 11:49 AM
jcottonoir
Oct 7, 2014 08:04 AM
