leak in diesel primer pump
Old Dec 8, 2010 | 03:20 PM
manny31's Avatar
Default leak in diesel primer pump
This morning I noticed my truck leaking diesel, looked under hood and found that the diesel primer pump was leaking with engine running. Has anyone seen this before? Can this be taken apart and O-rings changed? or what needs to be replaced?
Old Dec 8, 2010 | 03:38 PM
Threesixty's Avatar
complete lift pump needs replacing as far as I know. You can find them for around 100 bucks online, usually.
Old Dec 8, 2010 | 03:51 PM
12vcummins96's Avatar
you have to replace the whole lift pump
Old Dec 9, 2010 | 09:17 PM
manny31's Avatar
Default fixed
went to local bearing shop with old seal they matched it up, cost $5 done. put it together real easy fix.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
moneypitk5
Feb 12, 2015 11:01 AM
CumminsCoalRoller24/7
13
Dec 6, 2014 10:55 AM
