Cold start issue
Old Dec 8, 2010 | 11:30 AM
Luke7750's Avatar
Default Cold start issue
Hey guys I have searched for my exact problem with no luck and rather than hijacking someone elses thread thought I would start my own.
I have a 97 12V I purchased 1 month ago. It just started getting really cold at night. Around 18-30*. The last 2 days when I would try and start the truck I would wait for the heater then turn the key and it would start right away as smooth as can be. After approximatley 30 seconds the truck will start running very rough and die. After about 3 tries of starting the truck it will finally start up without any problems and start fine the rest of the day. Any suggestions. I just got the truck and the timing has been advanced to 15*, ddp fuel plate slid ff, starwheel 15 clicks forward, and afc ff. I have not plugged the truck up over night. I know this will help but something tells me this isn't the problem?
Old Dec 8, 2010 | 06:38 PM
SPLnut's Avatar
Sounds like its getting air in the system...Might wanna start with replacing the rubber fuel lines on the lift pump and return lines plus check your overflow valve
Old Dec 8, 2010 | 07:17 PM
tltruckparts's Avatar
i doubt you got a fuel leak, if you had a fuel leak it wouldnt start up right up and then die after thirty seconds. if it was a fuel leak itd be more like it has a hard time starting but clears up after a few seconds.
Old Dec 8, 2010 | 09:48 PM
12vcummins96's Avatar
what is your truck idling at
Old Dec 9, 2010 | 10:25 AM
Luke7750's Avatar
Between 1200 and 1500 rpm's when started in the morning.
Hopefully its something simple
Old Dec 9, 2010 | 10:04 PM
blazier18's Avatar
thats to much should be around 900 but that higher idle should help sooooo maybe u got fuel there but loose it somewhere else so u burn that fuel then it has to catch up
Old Dec 9, 2010 | 10:51 PM
Luke7750's Avatar
idk Do you guys think plugging the truck up may help or maybe my lift pump maybe going out?
Do you guys think it could be the fuel shut off solenoid?
Old Dec 9, 2010 | 11:38 PM
blazier18's Avatar
fuel shut off wouldnt let it die and pluggin it up could help quite a bit and its easier on the truck
Old Dec 10, 2010 | 10:47 AM
1stGen1990's Avatar
i dont know what tempurature diesel gels at but that could be it to
Old Dec 10, 2010 | 10:23 PM
Luke7750's Avatar
Here in NC its been in the mid 20's every night but my buddies have them around here and the are not seeming to have that issue but they have 24v's
Cavnar
Sep 9, 2015 07:18 PM
Mike0885
May 27, 2015 12:07 PM
ronstop
Feb 26, 2015 09:48 AM
custom7.3
Nov 24, 2014 05:16 PM
custom7.3
Nov 23, 2014 10:44 PM
