DRAGGING/ LOCKED UP FRONT BRAKES
Old Dec 8, 2010 | 08:19 AM
cumminsdieselizer's Avatar
Question DRAGGING/ LOCKED UP FRONT BRAKES
2001 DODGE RAM 2500 WITH 230000 MILES...2 weeks ago i was driving down the road and my front brakes started grabbing as i was driving thru town. the problem was progessivly getting worse untill they completly locked up. i first noticed the problem when i was cruzin about 30 mph and it felt like my truck had no power and it was working harder than it should be. pulled into a parking lot after putting the truck in 4 low and inspected the front end. to find a smoldering pile of brake dust and the rotor with sever gouging. got the truck towed home and inspected the front brakes driver side innner pad had 1/16 of pad left outter pad had 1/8 inch left, passenger side inner and outter pads had almost 3/8 of pad left on them. the truck wasnt pulling to left or right at all. does anyone have any ideas whats going on?
Old Dec 8, 2010 | 08:36 AM
Red_Rattler's Avatar
High Tech Redneck
Rubber lines could be swelled up and not allowing fluid back out also remove the caliper and pads and take a big channel lock and see how hard it is to push the pistons back in. Calipers could be froze up. For the uneven wear on one side gonna have to check and see how the slide pins that hold the caliper on look and move.
Old Dec 8, 2010 | 08:49 AM
Whit's Avatar
Site Mascot
I would do a complete brake job on the front and inspect the rear, dont forget new fluid all the way around, inspect rotors too, new ones arent bad and it sounds as if the originals may be warped anyway
Old Dec 8, 2010 | 08:54 AM
Whit's Avatar
Site Mascot
the 01.5 has discs on the rear and an 01 doesnt so if your truck is an 01 then do this on the rear as well.................very easy
https://www.dieselbombers.com/dodge-...r-upgrade.html
Old Dec 9, 2010 | 12:43 PM
01_cummins's Avatar
also if you just replaced your rotars that would deffinatly cuase it too becuase my friend replaced his and the parts store gave him rotars for a 4x4 and he needed 2x4 rotars and it did that then. just throwing some info out for ya!
Old Dec 15, 2010 | 06:04 AM
Blacksmoke Bulldog's Avatar
I had this happen on my 99. I replaced the hydraboost and calipers, but it ended up being a Brake master cylinder. the spring inside becomes weak and does not let the pressure leave the calipers.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Radioking1777
Jun 9, 2015 04:13 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
