New 98 Dodge diesel owner
Old Dec 6, 2010 | 10:42 PM
oldduallyfart's Avatar
Horn New 98 Dodge diesel owner
Men of the diesel world,i am a newcomer and have just purchased a 1998 dodge 3500 dually to pull my 30 foot travel trailer.Im having new upper and lower ball joints,tires,batteries,front end alignment and oil/fuel filter service.Is there anything else i should have checked.The truck has 140,000 miles.Also how can i tell what fuel pump i have.It was manufactured feb98.
Old Dec 6, 2010 | 10:57 PM
stodg73's Avatar
Congratulations, you have entered the great world of Diesels. Ask as many questions as you wish, some may know the answer, some may not, like me.
On the fuel pump question, do you have 12 valves or 24. If 12 valves you have the P7100 mechanical pump, if you have 24 valves you have the VP-44 electronic pump, and seeing that your mfg date is Feb.98, you could have a 98.5 which would be the VP-44 pump
Welcome to Diesel Bombers!!
Old Dec 6, 2010 | 11:12 PM
Default Thanks stodg73
Im not sure which i have till out of shop.The reason i asked about the fuel pump is i understand there are problems with the vp-44.
Old Dec 6, 2010 | 11:29 PM
stodg73's Avatar
The main problem with the VP-44 is the low pressure lift pump goes out and then takes out the VP. The first thing you should do is get a fuel pressure gauge and hook it up to the schreader valve on the VP and see what the pressure is. If it is below 10psi you need to look at getting a new lift pump. You may have the Dodge upgraded lift pump in the tank, they don't work so well. If so, you might want to look into a FASS, Airdog, or Raptor for a lift pump, along with a draw straw.
If the truck doesn't have gauges, look here for gauge information: Gauge Information Lots of information here.
Others will chime in.
Old Dec 7, 2010 | 03:51 AM
Thanks for the guage info.
cass_epp
Wanted To Buy (WTB) - Used
Mar 20, 2017 04:07 AM
elbedonie
May 19, 2015 10:16 AM
Cervezamoney
Feb 11, 2015 04:15 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
