Cliffs Drag Truck Thread
Old Dec 6, 2010 | 09:56 PM
Lostnwalmart's Avatar
Default Cliffs Drag Truck Thread
ok ok ok ok so i i figured it was about time i posted up a thread about my lil project. Its a 1994 single cab 2wd auto. i picked it up for 3700 and it was in great shape had some 70 hp injectors modified plate and afc along with a gear vendors and bd exhaust break. I bought the truck to be a play toy so im not concerned with issues like towing or fuel mileage this will be a street/strip rig only. This was the truck when i bought it
I then proceeded to take the wheels and tires i had from my old truck and mount then and i stripped her naked
I bumped the timing up to 16-17 degrees and ran her this way at the track. I got a 15.7 at 86 mph. Drove it like this untill i blew up the overdrive sun gear and with a huge thanks to BBD i got it rebuilt with a sun-coast triple disc converter billet input, sun-coast hd rebuild kit, and trans-go shift kit. I also put some 191 dvs, 4kgsk and a rack plug in it, took it to the track to run it down the 1/4 mile and blew up my turbo first pass (it was maxing out my 50 psi gauge) and ran a 15.2 at 93mph. Well i was low on money and i have had a hx60w sitting around for years so i figured what the heck ill give it a shot as a single. I made up an adapter plate, exhaust and charge air pipe and wala
the turbo came off of a isx signature 600 series engine and came with a Titanium compressor wheel and a flow rate of around 130 lbs a min. The turbo has a 5 in v-band and i made a 5 in turbo back with a 6 in stack.
I found a nitrous kit on craigslist for $200 with a big solenoid and a 10 lb bottle i rigged it up with a main power switch and a momentary toggle to light the turbo at the track. I also managed to get my hands on some II 5X18 injectors to get some fuel to the truck. With this setup i have ran a best of 13.598 at 106.48
I plan on getting slicks, cal tracks, losing the hitch spare tire and actually getting a real lift pump other than stock on the truck and dual feed it. The most recent addition are some dv's i installed from robs diesel that are similar to 191s in top end fuel but smoke less and spool better. I plan on keeping you guys updated as i progress in going way to fast. end goal is 11 sec range
-Cliff
Old Dec 7, 2010 | 05:30 AM
monster12valve's Avatar
keep us posted!
Old Dec 7, 2010 | 07:17 AM
85_305's Avatar
Being Evaluated
Wow those are some good numbers man.
And I cant believe how small that turbo is
Old Dec 7, 2010 | 09:32 AM
Its just a little guy, the crazy thing is that its not that bad on the street and the truck is still driven every day while the parents borrow the Jetta.
Old Dec 7, 2010 | 11:14 AM
94 12valve's Avatar
very cool
Old Dec 7, 2010 | 11:22 AM
24vmatt's Avatar
nice work mang
Old Dec 7, 2010 | 12:04 PM
angelic0-'s Avatar
LIKE, when does that turbo lit ? 5000rpm :')
Old Dec 7, 2010 | 06:38 PM
2400 actually
Old Dec 8, 2010 | 03:27 PM
12vcummins96's Avatar
this truck is very well mannered on the street with that charger
i enjoy working on it
Old Dec 10, 2010 | 09:09 AM
Coco2992's Avatar
you can work on mine too
