Holley Black? Install parts?
Old Dec 6, 2010 | 07:29 PM
cbchristian's Avatar
Default Holley Black? Install parts?
Found a bunch of threads on installing a Holley black. But know real parts list or installs. What would be the best way to install one? I was thinking that I could installthe pump and another fuel/water seperator then strait to the injection pump without a return line? Or is there a return line spot on the Holley Black? Kinda fuzzy on it any help appreciated.
Old Dec 6, 2010 | 09:52 PM
Mark Nixon's Avatar
The RETURN line is not plumbed through the fuel pump, it is a separate line that is clamped near the rear of the head and both the injector return line and the VE case overflow line tie into this with a 'T' fitting.
It has it's own dedicated return line back to the tank.
The fuel SUPPLY line is clamped directly to the old lift pump, follow that line rearward down the framerail to a point as close to the tank as possible.
Since your 1991-1/2 has steel fuel lines, you can install it in the line by simply cutting the steel line and splicing the new pump in by way of short rubber hose and hose clamps.
As far as a separator, the stock filter/separator seems to work just fine, just plumb the fuel supply line into the stock filter inlet line and you're good to go.
Mark.
Old Dec 6, 2010 | 10:26 PM
Thanks that helps alot.
Gman30
Dec 27, 2014 12:46 PM
carid
Towing and Hauling
Oct 27, 2014 10:46 AM
Sculpturesylvan
Oct 18, 2014 10:40 PM
Sculpturesylvan
Oct 18, 2014 10:19 PM
