Engine Noise
Old Dec 5, 2010 | 07:25 PM
bjennen's Avatar
Default Engine Noise
i bought a 94 GMC with a 6.5 turbo in it in October and only drive it every now and then, mainly for my hunting truck. My question is, a few days ago, it started making a noise and i'm trying to figure out what it is or if I should sell the truck before I dump more money in it. The noise to me sounds like its coming from the pulley under the a/c pulley. What is that? Is that the oil pump or something. Its making sorta like a knocking or loud ticking noise then every once and a while it will squeal. any advice will be apriciated. it has 186,000 on it. I think the owner before me didn't care too much about the truck and didnt take the best care of it but I got it for 1900 and everything but that has been working ok other than the starter and i fixed that.
Old Dec 5, 2010 | 07:42 PM
Crazy's Avatar
under the a/c pulley would be the vucuum pump
what kind noise it making they will make some noise
Old Dec 5, 2010 | 08:43 PM
bjennen's Avatar
Its almost like a ticking noise to a thumping noise and every once and a while it will squeal. are those expensive and hard to change??????
Old Dec 5, 2010 | 09:24 PM
Crazy's Avatar
i did way with mind so it maybe still hanging around and it still good i have look tomorrow see if still have
but i would first pull the belt off and spin pulley buy hand and make sure what pulley bad
Old Dec 6, 2010 | 07:46 AM
bjennen's Avatar
thank you very much i appriciate all your help
What do you mean you did away with yours, do you not need it or did you put a different kind on???
Old Dec 6, 2010 | 11:36 AM
Crazy's Avatar
i put in TM on
Sorry i look this morning for the vacuum pump must have junk it
Old Dec 6, 2010 | 12:07 PM
bjennen's Avatar
TM ??? What is that
Old Dec 6, 2010 | 01:00 PM
Crazy's Avatar
turbo master
where your truck is 94 1500 you still going to need vacuum pump to run the EGR or you want gut your intake or fine F intake then you can do away with the vacuum pump
Old Dec 6, 2010 | 01:01 PM
Crazy's Avatar
oh should also tell you if you run TM you need to run boost and EGT gauges
Old Dec 6, 2010 | 03:12 PM
bjennen's Avatar
Wow, sounds like I would be getting way in over my head.
Is there anyway to check the vacuum pump before i replace it, could it be the belt making it squeal? I don't want to replace the pump and then it be just the belt.
