Code 0208
Old Dec 5, 2010 | 11:21 AM
spokes's Avatar
Default Code 0208
Getting code 0208. Can i check and verify that my #8 injector is bad. I was also showing number one had the same code as well and showing a code for fcim low volts but cant remember the code off hand. I erased the codes and am now just showing up with the 0208
Old Dec 5, 2010 | 01:04 PM
deucer's Avatar
Fix your FICM low voltage first and it my correct your #1 & 8 injector issue.
http://www.bscustoms.net/diesel/FICM.pdf
Old Dec 5, 2010 | 09:09 PM
spokes's Avatar
sorry guys that code was not 0208 it is 0284 and the othe code was 1378
Old Dec 6, 2010 | 08:06 AM
Mdub707's Avatar
If you had a FICM code, fix the FICM. I've seen this before, truck throws FICM code, code is cleared, then the only codes that pop up for a while are injector codes, but the FICM is the root cause. If you fix the FICM, those injector codes will most likely disappear, but if not then you can replace them, but do the FICM first.
Old Dec 6, 2010 | 08:17 AM
deucer's Avatar
Code P0284 -Ford: Cylinder #8 Balance Fault
Code 1378 -Ford: (FICM) Supply Voltage Circuit Low
Fix your voltage issue at the FICM like Mdub said... If you will go to http://www.bscustoms.net/diesel/FICM.pdf it will give you help in fixing your problem.
Old Jan 17, 2012 | 07:53 PM
nadadwia's Avatar
getting a p0284 contribution balancefault and p0308 misfire cylendar 8 any suggestions?
Old Jan 18, 2012 | 08:43 AM
Mdub707's Avatar
Sounds like a dead injector. Check the harness going to the injector for chaffing. You can always try swapping it for another injector on the motor and see if the codes follow to the new cylinder. You can also put it on a scanner and shut it off to see if there is a difference in how it runs.
Does it feel like it's running on 7?
Old Jan 18, 2012 | 01:59 PM
nadadwia's Avatar
no it runs really good except at idle, it smokes hard with h=white smoke and there is a film of oil on the tail of the truck. once it warms up it is smooth, still getting 22 mpg but it acts like it is loading up on fuel when at idle.
Old Jan 18, 2012 | 02:54 PM
Mdub707's Avatar
22mpg? I wouldn't change a thing if I even thought there was a chance of me getting mileage that high.
What's the smoke coming out of the tail pipe smell like? Sweet like coolant, or burn your eyes like fuel?
Old Jan 18, 2012 | 04:15 PM
nadadwia's Avatar
the smoke smells like fuel, i am not loosing any coolant, there is not any in the oil nor is there any oil in the coolant. the truck is actually a 6.4 (2008 f250 crewcab 4wd), i cant complain about the performance. biggest issue i have is that it smokes like a skeeter fogger. when i bought the truck it had 100k on it i have put 40 on it in the last year, pull a boat a lot, a 5th wheel travel trailer to Padre island and back ( i live outside TUlsa) and get 16 when pulling the trailer at 70.
the truck started doing this i guess the first time was about 3 months ago, i let it run to warm up while i ran inside to get a coke for the road when i came back out it was running like it was dying and smoking to beat all hell so i killed the motor and started checking everything, (i have heard horror stories about the egr leaking coolant into the block) when everything was full i turned the key to see what it would do, it started right up, no smoke not making any noises or anything, took it to Ford and ran the codes, none.
Sunday morning when i started it and let the truck warm up it started smoking some (hard to tell in the dark) and after the engine revved itself up during the warm up it started to smoke really hard and then running like a miss and the check engine came on, took it to my regular gas mechanic and we ran the codes i get an 0284 and 0308 misfire on cylendar 8 and the balance code.
we ran the glow plugs and injectors and everything checks out ok on the scanner.
