wont run wortha crap
Old Dec 4, 2010 | 06:28 PM
CorpusChristideisel's Avatar
Default wont run wortha crap
have a 92 w250 just had the pump rebuilt at pensicola diesel put it in and its doing the same not running worth a **** have it floored and it barely wants to run at idle....NEED HELP
Old Dec 4, 2010 | 07:04 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
give us some more info. will the truck idle by itself. do you have any gauges.
Old Dec 4, 2010 | 07:16 PM
tltruckparts's Avatar
have you checked your shut down solenoid, there is a chance that it could be opening but not all of the way. and its the actual solenoid on the pump not the one on the firewall
Old Dec 4, 2010 | 07:33 PM
wont run on its own have to keep it floored to even run and when it does fire up it sounds like crap and no gauges
Old Dec 4, 2010 | 07:52 PM
i bet its your shut down solenoid they normally dont replace those when they rebuild a pump. pull it out and gut it put a shown cable on it and be done. or there is a link in the sticky you can get it for 10 bucks. check to make sure you have good 12 volts to the solenoid first though
Old Dec 4, 2010 | 08:24 PM
what is a shown cable
Old Dec 4, 2010 | 08:27 PM
moneyman_09's Avatar
I think he meant shut down cable, It's basically a choke cable you attach to your manual shut off lever to pull from inside the cab when you want to shut the truck off.
Old Dec 4, 2010 | 08:49 PM
how do i gut the solinoid
Old Dec 4, 2010 | 08:54 PM
I'm not real sure i bought mine with a pull cable. check the sticky
Old Dec 4, 2010 | 09:29 PM
whats the sticky
never mind
Last edited by CorpusChristideisel; Dec 4, 2010 at 09:29 PM. Reason: Automerged Doublepost
