Psi performer fuel system
Old Mar 23, 2007 | 11:38 PM
spooler's Avatar
Default Psi performer fuel system
It took about thirty minutes to install and it works flawlessly. The pump is advertised as 150000 mile pump. There are no springs to change. Quick start ups and exellent idle and fuel pressure. With two stacked programs,I've seen the low side at 10 psi at wot, and 14-15 psi at cruise.
Old Mar 24, 2007 | 11:46 AM
DazedandConfused's Avatar
Mine is going on today with pics hopefully.
Andy
Old Mar 24, 2007 | 06:48 PM
spooler's Avatar
Default performer pump
Just a bit of info for you. In 2004 dodges warranty work on trucks they put a pump intank if the lift pump had went out. So if you have any problems getting fuel to the injection pump you might have pump intank. The red wire coming out of the harness is a prime wire. When every thing is hooked up prime the pump by touching it on the battery. Good luck
Old Mar 25, 2007 | 08:02 PM
Well I got mine installed today and man does my truck run better. My stock fuel pump took a crap on me so I had no choice. I also cleaned the air filter, took it for a ride and the trans locked in first and It lit the tires up. I really need to invest in a new trans.
Andy
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
