Factory gauges?????
Old Dec 3, 2010 | 11:53 PM
Paranoid1123's Avatar
Default Factory gauges?????
How accurate ate the stock boost & trans temp gauge? I i I was thinking about getting a 3 pod pillar and was wondering if I should forgo getting a boost and trans temp gauge, since my cluster already has one?
Old Dec 4, 2010 | 01:10 AM
Goose350's Avatar
boost is accurate. Trans is somewhat.... Do you tow a lot? If not I would skip the trans temp. If you are going to get a 3-pod I would get EGT, Fuel pressure and EOT.
But, I would recommend getting a Edge Insight. That way you can monitor EOT, ECT, EGT, Trans, Boost and more.
Old Dec 4, 2010 | 01:19 AM
The only thing I tow is a 30" camper and it is only 9000lb loaded.
I don't want an edge because it is too easy to steal. I live in houston and work in a lot of different refinery so big wide open parking lot where my trucks sits for 12-16 hrs/day.
Old Dec 4, 2010 | 10:37 AM
Goose350's Avatar
The 5r110 doesnt get that hot. I would recomend getting a 4-pod and get EGT, Fuel Press, EOT and ECT.
Old Dec 4, 2010 | 03:18 PM
Mdub707's Avatar
Yeah, what goose said.
Old Dec 4, 2010 | 08:40 PM
I think I found a way to turn a 3 pillar gauge pod into a 5 gauge. So I'm going to go with egt, temp (oil, trans, coolant) fuel pressure. I'm just going to put a toggle switch on the temp gauge so I can switch between the three.
flainn
Oct 12, 2024 09:39 AM
May 1, 2015 08:10 AM
