Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
2004 duramax lly will crank but wont start
Old Dec 3, 2010 | 10:40 PM
erics1983's Avatar
Default 2004 duramax lly will crank but wont start
I have a 2004 Chevy Duramax LLY 6.6 turbo diesel that will crank but wont start. Will on run ether. Checked all fuses and they are good. Checked glow plugs and are working. Injection box is working. No DTC's. Repaired wiring harness above alternator on passenger side. Replaced fuel pump filter and water sensor. Fuel rail pressures are good. Need help to figure out why it wont start.
Old Jun 2, 2011 | 09:05 PM
bamaboy's Avatar
try replaceing fuel filter housing
Old Jun 2, 2011 | 09:23 PM
2009RavenR1's Avatar
Will the truck prime if you pump the primer? Does it ever get hard? And stop spraying ether into the truck before you break it from the motor running away!!!
Old Jun 2, 2011 | 10:10 PM
Rttoys's Avatar
This thread is 7 months old, I'm sure he's fixed it somehow by now.
Old Jun 2, 2011 | 10:12 PM
well... ****
Old Jun 3, 2011 | 09:14 PM
Rttoys's Avatar
ish1521
Aug 26, 2015 08:42 PM
ronstop
Feb 26, 2015 09:48 AM
HKLBRY
Feb 18, 2015 09:46 PM
HKLBRY
Feb 17, 2015 08:52 PM
musikagod
11
Nov 30, 2014 07:22 AM
