Freeze plugs
Old Dec 3, 2010 | 02:07 PM
angelic0-'s Avatar
Default Freeze plugs
One of my freeze plug has come out (not sure why though) how much is a new one and shouldn't i tear down the motor to check if any other freeze plug has come out ?
Old Dec 3, 2010 | 02:19 PM
cummins_guy's Avatar
the only time I have seen that happen, when you do not have the correct 50/50 antifreeze
if there is to much water, it can start to freeze and it will push on all the freeze plugs (hence the name freeze plug)
I would just buy another one and put it back in place, use some type of sealant when putting it in, I use locktite (red) when I do a build
Old Dec 3, 2010 | 02:23 PM
angelic0-'s Avatar
so, i shouldn't be afraid of the block being cracked and such ?
Old Dec 3, 2010 | 02:44 PM
if you start to loose fluid after you have fixed it, then yes you could have cracked the head or block , you may have also just messed up the head gasket. (if you have done any damage at all)
don't freak out just yet, just fix what is broken and go from there.if you cracked the block or head you will be able to see signs.
Old Dec 3, 2010 | 03:28 PM
brindle_bull's Avatar
yep, the freeze plugs are actually supposed to help prevent those cracking hopefully you got lucky and yours did what it was supposed to do
Old Dec 3, 2010 | 07:45 PM
joshmock's Avatar
any help with finding the correct freeze plug for the rear passenger side freeze plug. i found some from rock auto but they got all sorts. just wanna do an oem replacement, don't wanna do the bolt in or anything
Old Dec 4, 2010 | 06:31 PM
smoken's Avatar
I had one rust through so I replaced all of them buy them from Cummins they where only a couple bucks apiece and use some sort of sealant, I used loc-tite black RTV and working great
Old Dec 4, 2010 | 06:37 PM
lodal cummins's Avatar
what is the best method of pulling them out, as i have one on the old 92 that is starting to rust.
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
1997silverado
Mar 12, 2015 07:40 PM
hardwired
8
Jan 23, 2015 04:30 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
