classic hp question guessin
Old Dec 3, 2010 | 01:00 PM
luke46's Avatar
Default classic hp question guessin
How much power y'all reckon I'm makin no local dyno so just asking the classic guess from everyone's experience. I know I can smoke my father in laws 06.
Old Dec 3, 2010 | 04:48 PM
dukeboy_318's Avatar
im assuming your truck is an auto tranny? if so, based on your signature and compared to a baseline done on a dyno of stock truck from the same year, your baseline rear wheel number is probably around 150-165 hp, 350-400 ft lbs, with what is in your signature and no tranny upgrades, i would venture to say somewhere between 240-290 rear wheel hp and 600-750 ft lbs.
now before you say what the factory rated it at, let me remind you that the factory rates the hp and torque at the flywheel, one usually sees a 30-35 percent loss of power through an auto, a tad less through a manual.
Old Dec 3, 2010 | 10:49 PM
RAW's Avatar
RAW
What kind of boost can you make, and what color is the exhaust exiting the pipe?
Old Dec 7, 2010 | 12:55 PM
luke46's Avatar
All in my sig says 5 speed and 32psi boost thanks and it's pretty clear exhaust surprisingly
Old Dec 7, 2010 | 01:19 PM
Turbolvr's Avatar
I'd say your in the 325/725 neighborhood. you can raise boost 2-3psi more but then your out of turbo.
Old Dec 7, 2010 | 01:25 PM
Farmboy 2.0's Avatar
Id say around 300 or so to the rear tires
Old Dec 7, 2010 | 06:23 PM
01quadcab's Avatar
add an edge comp and your be in the 350hp range I did 319 with mine on stock injectors and 360 with some bosh rv275's.
Old Dec 7, 2010 | 08:13 PM
Rooster24v's Avatar
Yep id agree with scott@alligator, id have to guess right around 300 or so.
Old Dec 7, 2010 | 08:17 PM
Id say around 300-325 depending on the condition of your VP44.
Old Dec 7, 2010 | 10:02 PM
kyle davis's Avatar
not to thread hack either but i alos wonder what i am making, any ideas for my numbers my edge seems to be more efficent on like 1,2,3 and just dumps fuel on 4,5,6...
