Exhuast
Old Dec 3, 2010 | 09:08 AM
SixFivePower's Avatar
Default Exhuast
Any benifit to having stacks? I figure that since the overall length of the exhuast is shorter and 1/3 of it could be 5in. it would be pretty loud. Right now I have a 3in. strait back with a 4.5in. tip. I want my truck to be as loud as possible. Suggestions?
Old Dec 4, 2010 | 01:33 PM
Woody35's Avatar
get a 4 inch exhaust system it will be louder
Old Dec 5, 2010 | 09:07 AM
thirdstreettito's Avatar
What truck do you have? What engine? Any mods?
Old Dec 6, 2010 | 08:41 AM
92' Chevy Cheyenne 2500 with the 6.5L Turbo, no mods.
Will a 93' exhaust from Diamond Eye fit my 92'? and would a Glasspak fit/work and make it louder?
Last edited by SixFivePower; Dec 6, 2010 at 08:41 AM. Reason: Automerged Doublepost
Old Dec 6, 2010 | 09:23 AM
If the trucks are the same bodystyle and engine then yes it will fit. Straight pipe is the loudest for diesels. A glasspack doesnt really do much except keep johnny law from trying to ticket you for no muffler. Also, if your truck is a turbo 92 it is a 6.2 turbo diesel. 6.5's came out in 93.
Old Dec 6, 2010 | 03:06 PM
The 6.5L TD was introduced in 92' trucks actually. 93' was significant to the 6.2L because it's when GM threw it out the door.
Old Dec 6, 2010 | 05:29 PM
I've heard both. The problem is nobody has GM papers to prove either.
Old Dec 6, 2010 | 06:19 PM
steve32's Avatar
would a true 6" straight piped exhaust be louder than a 4" straight piped? would 6" stacks be better and louder than both? and i'm talking 6" from the Y pipe all the way out the bed of the truck.
Old Dec 6, 2010 | 06:24 PM
It will be louder, but it will sound like crap, its like yelling in the Lincoln Tunnel, its dumb. Plus these engines dont put out enough air for a 6" to be efficient. Basically because there is less air than there is space in the pipe the air wont know which way to go and will create back pressure. Diesels dont need back pressure, so by using too large of a diameter pipe you get a negative effect on the engine.
Old Dec 6, 2010 | 06:28 PM
steve32's Avatar
so a tru 4" straight piped exhaust would be the way to go? i have a 4" exhaust on the truck right now(stock). taking out the cat, would that b all i would need to tak out to make it a true 4" exhaust or is there something else the has a smaller diameter pipe inside?
