Grid Heater??
Old Dec 3, 2010 | 07:22 AM
Get Rowdy's Avatar
Default Grid Heater??
wheres the timer located on the grid heater change the solenoids still not working want to find the timer and try changing that next any one know?
Old Dec 3, 2010 | 08:28 AM
kieron_kohlmann's Avatar
Its in the computer.
Old Dec 3, 2010 | 11:06 AM
1stGen1990's Avatar
ya the computer runs the grid heaters and somethin else and thats all on these trucks. pretty basic
Old Dec 3, 2010 | 01:01 PM
Get Rowdy's Avatar
what would i have to do to fix it
Old Dec 3, 2010 | 07:02 PM
Mark Nixon's Avatar
On a Non-intercooled '91 the "timer" is on the firewall, near the column.
On a '91.5 (Intercooled) it's behind the battery in the fender.
There are several reasons the grid heaters won't activate and a bad timer is only 1.
You could have a bad air temp sensor or bad wiring connections from the timer to the solenoids.
Troubleshoot it like you would anything else, verify that each peripheral component works, such as the solenoids and the grid heating elements.
Mark.
Old Dec 6, 2010 | 06:45 AM
Get Rowdy's Avatar
solenoids are good where is the air temp sensor located
Old Dec 6, 2010 | 07:30 AM
top of the manifold(2 pin). their is an entire book about grid heater diagnosis and operation in the sticky that shows its location( i believe)
Old Dec 6, 2010 | 08:56 AM
Mark Nixon's Avatar
If it's a non-intercooled '91, the air temp sensor is located in the head, directly below the grid heater elements and passes through the large throttle bracket assembly.
Mark.
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Rooster24v
15
Jan 4, 2015 08:20 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
