Heat senor leak on Fuel filter.
Old Dec 2, 2010 | 06:05 PM
J.schiller's Avatar
Default Heat senor leak on Fuel filter.
How to fix small leak on fuel canister ? Its the heater on the top and leaks around the rubber seal,
Old Dec 2, 2010 | 09:30 PM
RAW's Avatar
RAW
My drain valve was leaking once, I took it apart and installed new o-rings and it has been fine ever since. First thing you need to do is figure out what/where the leak is, then we can decide the best action to repair it.
Old Dec 3, 2010 | 05:25 AM
J.schiller's Avatar
its the rubber seal around the heater wires on the top of the fuel fiter mount.
Old Dec 3, 2010 | 07:20 AM
RAW's Avatar
RAW
Around the base of the heater, or coming out through the center of the heater where the wires are. If its the latter, new heater would probably be the best fix. If its around the base, a new o-ring.
Old Dec 3, 2010 | 04:26 PM
J.schiller's Avatar
Its around the outside of the heater. How would you take it out and find the part? Dodge does not sell it and wants replace the whole filter canister
Old Dec 3, 2010 | 04:29 PM
The fix is to get yourself a GOOD lift pump with filters and take the OEM filter housing out. Airdog or FASS.
jeffersonl
Nov 15, 2015 07:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
