help me with my cablights
Old Dec 2, 2010 | 05:22 PM
FIRST GEN. JAKE's Avatar
Default help me with my cablights
i bought a set of recon smoked leds cablights to put on my truck. my truck didnt have factory cablights. i mounted the lights and wired em up and touched the ground off the check em and they light fine then when i checked em again the one on the end was really dim. so i tried bout everything i could think of, re wired it checked voltage, ground, and it was still dimmer. i wired in my hot in a different place and it helped some, so i decided to leave it be. i put my interior all back and drove it too town, all the lights where working fine. then i shut them off and back on to check them and now the second to last light is really dim and the last one is light up correct. what the hell is going on? i cant figure it out. i got 12 v at the end of my wire. there hooked up in series. i cant figure it out. any help is apprieciated.
Old Dec 2, 2010 | 05:42 PM
daveO's Avatar
I had a buddy that put the LED cablights on and had similar problems. Some of them were different shades of amber, some of them were dim. I would give recon a call, it seems like perhaps you got bad LED assemblies.
Old Dec 2, 2010 | 06:10 PM
well only problem is i bought them used instead of new
Old Dec 2, 2010 | 06:45 PM
brindle_bull's Avatar
never know recon might stand behind them anyways
Old Dec 2, 2010 | 07:52 PM
kieron_kohlmann's Avatar
depends on wether you wire them in series or parallel. they need to be in parallel.
Old Dec 3, 2010 | 06:53 AM
KD93's Avatar
He said he wired 'em up in series. ^^^^^
As Kieron said, wire them in parallel. Or if you want to be really fancy, series/parallel like your headlights.
Old Dec 3, 2010 | 08:44 AM
The problem with wiring them up in series is that each bulb in theory is dropping the same voltage. the problem is that they are not exactly the same. Thus the bulbs with more resistance through them are robbing the voltage from the other ones that have less resistance. In a perfect world they would all be the same brightness but their not. Your easiest bet is to wire them up in parallel. Then each light will be dropping 12 volts, making it light to its maximum potential.
Old Dec 3, 2010 | 08:54 AM
AF1CUMMINS's Avatar
Not electrically inclined.....what does this mean?
Old Dec 3, 2010 | 02:06 PM
run a 12 volt a power wire to each light.
Old Dec 3, 2010 | 02:13 PM
cummins_guy's Avatar
just turn on your lights and take out the bulb that is first in line to receive juice from the battery, if all your lights go out, then you have it in series, if they do not you have it in parallel.
all vehicles are (should be) wired in parallel because if you loose one head light, you still have the other to get you home.
if that company will not help you out, you can go to your local autozone and they should have the led cab lights in stock (the autozone in my town always have them in stock)
hope this helps
