still workin on the cab change and hatin NY
Old Dec 2, 2010 | 03:57 PM
prison's Avatar
Default still workin on the cab change and hatin NY
so i got my 94 cab sittin on my 85 frame. i'm lookin for a wiring diagram so i can use my old engine wiring. this project sucks in the winter
Old Dec 3, 2010 | 01:19 PM
CARP's Avatar
Yeah! Winters in Buffalo are brutal! I used to reside in Lockport, about 25 minutes north. Hope you like the snow
Old Dec 4, 2010 | 02:14 PM
prison's Avatar
anybody got a diagram by chance for 94 cab and idi engine? and ya this snow blows. replaced shear pins in the snowblower already because i left a 2x4 in the driveway. Then the torpedo heater ran outta kerosene and couldn't find a station with any and when i finally did they had already shut it down for the night
Old Dec 4, 2010 | 05:54 PM
DieselCrawler's Avatar
they will run on diesel and home heating oil also. i run mine on all 3. matters what i have at the shop
Old Dec 4, 2010 | 06:05 PM
tltruckparts's Avatar
good luck. i tried doing that on my tow truck and found it much easier just to bolt a powerstroke in so everything plugged into each other
Old Dec 4, 2010 | 09:28 PM
prison's Avatar
well in 94 ford still had the idi so the connectors should be the same. although the cab came off a powerstroke. i'd like to speak to you more on the idi to powerstroke switch
Old Dec 5, 2010 | 12:20 AM
i went from a 90 cab with a 460 to a 97 cab with a pwerstroke nothing was even close. but on a 94 it might be alot easier with the newer cab already having the right wiring connectors. if the connectors plug into each other itll be alot easier. mine wouldnt even plug in so it was just easier to swap everything out
Old Dec 5, 2010 | 02:55 AM
FastCR's Avatar
I'm not a ford guy, but haynes manuals are your friend. What year motor are you running?
Old Dec 5, 2010 | 11:55 PM
tiremann9669's Avatar
Whats the matter, few feet of snow hampering things ?
Old Dec 10, 2010 | 10:12 PM
green thang's Avatar
ic ya need anything im right around the street if ya need a hand message me
