P pump for conversion
Old Dec 1, 2010 | 10:42 PM
navy_welder's Avatar
Default P pump for conversion
Just wanting to see about how much a p pump is goin to cost so I can do a swap on my truck .. I'm not looking for anything fancy just want a basic pump but just throw me some numbers so I can do this swap I'll also be looking for the rest of the swap parts as well pump gear and timing case and fuel cable and braket and all those goodies
Old Dec 2, 2010 | 05:20 AM
blazier18's Avatar
im thinkin u have to get a different fron cover too and 600 or more for a good pump with injection lines but also depends on wat size pipe u want.
Old Dec 2, 2010 | 08:03 AM
Is that your price I just want a pump that is easy to find and cheapest I can find And I do need the front cover and stuff
And is that price for 24v p pump lines as well
Last edited by navy_welder; Dec 2, 2010 at 08:03 AM. Reason: Automerged Doublepost
Old Dec 2, 2010 | 08:11 AM
blazier18's Avatar
no but ill look around for u
Old Dec 2, 2010 | 07:23 PM
Thank you I appreciate it I want to keep my truck but I can't sit here and keep throw ip and ecms at it and this seems the only way to keep it and the ole lady hates it when I spend money on the truck she thinks my truck is more important than her haha maybe she's right I do love my truck when I bought it it was bad off and I have gotten it to decent on the eyes and I hate to get rid of something I have spent so much time on
Ok so I found the whole shabang for the swap except injection lines and throttle cable for 650 how bad of a deal is that it comes with a p pump and all the brakets and gear case and fuel shutoff and all the linkage and the pump gear and mechanical lift pump if I have the spot for it and the oil lines and fuel line assorted and everything
So really all I am needing is some injection lines and cable and to take out my injectors and get the pop off reset to p pump pressure then I will be ready for the teardown I hope if I can get everything
Last edited by navy_welder; Dec 2, 2010 at 07:23 PM. Reason: Automerged Doublepost
Old Dec 7, 2010 | 02:34 AM
blazier18's Avatar
depends on wat shape its in sorry for the late response and there pretty much indistructable secondly before u put it on get it flowed balanced and see wat the timing has been set too if its over 16.5 make it 16.5 especially if u have stock head gasket and headbolts. injection lines are kinda expensive. call around local junkyards for those.
and turbostang has all the wiring shabang for your truck as long as its 98.5-2002
Old Dec 9, 2010 | 10:48 AM
connermcpherson's Avatar
mine costed about 2k to do. The big expenses were the lines and ****. my lines, spacer, and cam sensor relo was about $550. I got a 175 and everything including the front cover and gears for about $1100 plus added **** i put on like a filter relocation and ****. When you do your pump, stay away from the 12v throttle assembly, it messes with the shifts on your tranny. i took my stock throttle bracket and torched a couple pieces to make it fit, and just connected all the stock throttle lines except for the pump throttle rod, which i just welded the the 12v ball on the 24v throttle and was good to go. if you need any help, pics anything let me know
Old Dec 9, 2010 | 07:09 PM
Will it mess up with a manual tranny
And I was told the only gear I need is the p pump gear do I need others as well
Last edited by navy_welder; Dec 9, 2010 at 07:09 PM. Reason: Automerged Doublepost
Old Dec 9, 2010 | 08:10 PM
prison's Avatar
i believe he's reffering to an auto trans. manual trans i'd say you'd be ok
Old Dec 9, 2010 | 09:59 PM
blazier18's Avatar
id talk to bigbaddiesel dont call a dealership they prob dont know wat a ppumped 24 valve is theyll say u need a oil change come on in.
