What govenor spring
Old Dec 1, 2010 | 10:23 PM
fumminsplease's Avatar
Question What govenor spring
Do you guys think I should get a 3200, 3800, or 4000 govenor spring? They all cost the same. Thanks
Old Dec 1, 2010 | 11:34 PM
big bad diesel 416's Avatar
Site Sponsor
anything after 3200 the fuel curve starts to fall off on the VE pumps so if you spin 4K you will just be making more noise
Old Dec 2, 2010 | 07:08 AM
KD93's Avatar
And giving your con rods and valves a hard time.
Old Dec 3, 2010 | 11:19 AM
1stGen1990's Avatar
ya 3200 is about it thats still reliable on stock parts. past that valves will float and you run the risk of the rods thrown themselves thrugh the block
Old Dec 5, 2010 | 10:06 AM
SNOOT's Avatar
But if you wana go real fast mph its not a bad option..
MPH in drive 3rd gear 70-90mph 3200gov spring
MPH in drive 3rd gear 80-100mph 4200gov spring
Overdrive hang on....
Old Dec 5, 2010 | 11:04 AM
Site Sponsor
ya I run a 4000 spring but you may go faster but with little power in that RPM range if you were building a salt flat truck then ya spinning 4K is worth it for drag racing no difference I still shifted at 3500 RPM you can actualy feel the truck loose power when its tuned right
