any advise
Old Dec 1, 2010 | 05:00 PM
beerlvr's Avatar
Default any advise
ok i just ordered everything , HS XRT pro with overdrive , flow pro 5" , HS EGR delete, and isspro gauges , this is my first 6.7 , any problems anyone had deleting anything or is it pretty strait forward? it looks pretty easy to do.. but i've said that before and been wrong..
Old Dec 1, 2010 | 06:20 PM
dodgeram082500's Avatar
did you get the cooler delete as well? the egr/dpf delete was pretty easy. everything pretty much is turn bolt take off put on
Old Dec 1, 2010 | 07:40 PM
beerlvr's Avatar
yea got the egr/ cooler kit
Old Dec 1, 2010 | 08:47 PM
yj junker's Avatar
no advice for you yet ,going to try it shortly myself,going to make my own 5" straight exhaust and put on a h&s mini max ,egr.&cooler delete
Old Dec 1, 2010 | 09:32 PM
barkrulz's Avatar
Super simple did it in my drive way in a day, i did the mini maxx tho.
I also ordered the shibby engineering connector kit. It puts a blank connector back in all the stuff you unplug to keep dirt and water out.
i also used a rail plug, if you plug it or shim it, use a six sided socket as that thing is hella tight and doesn't have much of a land on it for socket bite. also you will probably need an intake gasket if you do plug/shim the rail.
The night b-4 ya do it hit all the exhaust bolts and the tranny mounts/cross member with some PB Blaster after the vehicle cools.
PM sent
Old Dec 2, 2010 | 05:04 PM
beerlvr's Avatar
thanks , just waiting on parts now, anyone know what size drill bit to use for the 1/8 NPT tap, everywhere says R , is there another size
nevermind figured it out they had it a napa mine must have walked off..
hate when my tools do that,
Old Dec 2, 2010 | 10:51 PM
barkrulz's Avatar
mine grow legs whenever the kid or wife gets near the cabnet. a nickle for every time........
Old Dec 6, 2010 | 02:53 PM
beerlvr's Avatar
XRT PRO will be here tomorrow, time to get started hope i can find extra time, dont want to wait til the weekend
Old Dec 6, 2010 | 06:14 PM
DAFBFD58's Avatar
You have two options for doing the probe. Since our manifolds are pretty easy to get at its really a 50/50. You can take it off and drill and tap it. Or you can keep the motor running and keep the rpms up, like 1000, and heavily grease the drill and tap. That way any shavings get stuck to the grease or blown out by the exhaust. Just the two ways I have seen it done with perfect results.
cummins Pride
Sep 11, 2015 04:37 PM
bksrt8
Jun 15, 2015 05:52 AM
ChgoSquad5
Ford Powerstroke 2011-Up 6.7L
Jan 6, 2015 11:37 PM
Duramax1228
Nov 10, 2014 08:04 PM
Bradtex25
14
Sep 30, 2014 10:15 AM
