12V Manual Steel Heater Line (Pic Inside)
Old Nov 12, 2007 | 04:56 PM
IC Smoke's Avatar
Default 12V Manual Steel Heater Line (Pic Inside)
Im looking for a heater line off a 12V manual to complete my twin setup before fabrication.
pic:
Thanks
Ian
Old Nov 12, 2007 | 06:58 PM
Whit's Avatar
Site Mascot
IAN....its simple....get some SS tubing and a bender and make some brand new stuff
this is assuming that you have some kinna industrial connections to the stuff anyway
Old Nov 14, 2007 | 09:42 AM
Not quite that simple...I was changing oil last night, I measured lines and the OD is .65". It would be much easier if they were 1/2" - you could bend them up in a matter of minutes.
Id think the flow through 1/2" line would be a lot less ???
Old Nov 14, 2007 | 06:22 PM
saab9k's Avatar
It is easy, the local hose and fitting shop here in town can remake a/c solid lines with hose on the end, they make up ps steel lines for me at 1/3 the cost.
Looks factory too, can expand and / or shrink ends too
Old Nov 14, 2007 | 08:16 PM
IC Smoke's Avatar
its just radiator line, I dont need compression fittings or anything fancy. just wanted to look "stock" stock is 5/8 Ive got a chunk of rubber hose doing the job currently but Ill have to change it soon before the hair dryers are finished
Oct 30, 2014 08:10 AM
