fuel plate 96 5 speed
Old Nov 30, 2010 | 08:25 AM
96 Ram 5.9 turbo's Avatar
Default fuel plate 96 5 speed
I know that there are several ways you can do it but i was wondering what the most effective way to grind off a fuel plate is (shape)
Old Nov 30, 2010 | 09:11 AM
Whit's Avatar
Site Mascot
all depends what you want.....myself I like to do a 100 plate which basically keeps the stock profile for the first couple hundred RPM then allows for no fuel restriction for the rest of the power band, a 100 plate is best for the drive train as IMHO the takeoff is where it all gets tore up from the hard starts
I have made many 100 plates from OEM plates
Old Nov 30, 2010 | 09:33 AM
brindle_bull's Avatar
x2 the 100 plate seems to be the most popular with a little restriction at the first...otherwise take it completely out and let your foot be the plate
Old Nov 30, 2010 | 02:51 PM
do you think that it would be easier to buy a plate or grind it off myself? if you think it would be easier to grind do you know anywhere there is good photographs of one?
Old Nov 30, 2010 | 03:08 PM
Whit's Avatar
Site Mascot
this thread may help
https://www.dieselbombers.com/12-val...-profiles.html
Old Nov 30, 2010 | 11:03 PM
bulldog77's Avatar
Old Nov 30, 2010 | 11:55 PM
blazier18's Avatar
Originally Posted by bulldog77
i like that!
Old Dec 1, 2010 | 12:59 AM
FastCR's Avatar
x2 on that second pic, its the go to resource for profiles.
100 seems to be the way to go. I pulled mine. Not much clutch slipping, but when i installed 215 sticks i toasted the clutch.
Fill out your sig on your mods, it will give us a better idea of what your working with. If your going that aggressive, you need to know your EGTs. Start saving for a southbend before you do anything.
To answer your original question, the best method to grind the plate from what I've seen is with a die grinder. Make the profile you want from that 2nd pic, then damn near polish it. Its not the end of the world, but theres a pin that slides up the plate and if it catches it can give you problems.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
