DR PERFORMANCE DEAD PEDAL
Old Nov 29, 2010 | 09:48 PM
BIGBOY's Avatar
Default DR PERFORMANCE DEAD PEDAL
HI
I'VE BEEN A MEMBER FOR A WHILE, BUT THIS IS MY FIRST POST.
I HAVE A 99 CTD QUAD CAB 4X4 WITH FEW MODS.-4" STRAIGHT EX.,
JACOBS EX. BRAKE,BD LIFT PUMP, K&N, BILLET TORQUE CONVERTER IN A 47RE I
REBUILT MYSELF.
THE PROBLEM, THOUGHT I'D TRY BUYING A MODULE OFF EBAY.
USED DR PERFORMANCE PREDATOR STAGE 3.
INSTALLED IT TODAY IN ABOUT 25 MIN. RAN GREAT!!!
AFTER DRIVING HOME I DEVELOPED A DEAD PEDAL TO HALF THROTTLE.
CHECKED ALL CONNECTIONS,SEEM GOOD. DISCONNECT AND THE PROBLEM
GOES AWAY. QUESTION-DOES THIS MODULE DEMAND ENOUGH FUEL TO CAUSE
A STARVATION CONITION AT LOW RPM OR SHOULD IT HAVE A BETTER LIFT PUMP
EVEN FOR LOW RPM DEMANDS? MAYBE A BAD MODULE AND I'M THE SUCKER THAT BOUGHT IT.!!!
Old Nov 30, 2010 | 05:56 PM
crzycummins's Avatar
dont know much about them...have you checked for any codes? what is your fuel pressure doing? i would highly doubt that it takes too much fuel. but i could be wrong
Old Nov 30, 2010 | 07:45 PM
Whit's Avatar
Site Mascot
I wouldnt run it with a stock fuel feed, need to upgrade it ..............check for codes too, may have sent the truck into limp mode
Old Dec 4, 2010 | 04:07 PM
BIGBOY's Avatar
THANK TOU FOR YOUR RESPONSES,
I HAD PUT MY TRUCK IN LIMP MODE BECAUSE OF LOW FUEL PRESSURE TO LIFT PUMP.
NEW 140GPH PUMP ON THE WAY. JUST TAKIN IT EASY TILL IT COMES IN. I APPRECIATE THE HELP.
THANKS AGAIN.
scottxmorris
Jan 11, 2025 11:24 PM
burndiesel
10
Feb 7, 2023 01:15 AM
Daylon
Aug 23, 2015 11:01 AM
robbyS
Apr 16, 2015 02:22 PM
