Driveline Vibe
Old Nov 12, 2007 | 02:22 PM
alaskaflyer's Avatar
Default Driveline Vibe
Between 65 and 70 MPH I get a rotational vibe, only at these speeds though, I can feel it mostly in the pedal. Has anyone come across this before? I almost dread taking to the dealer.
Thanks
Gary
Old Nov 13, 2007 | 03:08 PM
CHEMMINS's Avatar
Is your truck lifted at all?
Old Nov 13, 2007 | 03:39 PM
Whit's Avatar
Site Mascot
check yer carrier bearing on the driveline........you can greese them with a needle zert
Old Nov 13, 2007 | 07:39 PM
My suspension is stock.
I'll grease everything up and see what that does.
This is one of my concerns, I'm getting ready to lift it and if I already have a driveline vibe how bad will it get after I lift it.
Last edited by alaskaflyer; Nov 13, 2007 at 07:39 PM. Reason: Automerged Doublepost
Old Nov 13, 2007 | 08:33 PM
madmanwithmouse's Avatar
I had to replace mine at 10k, and the U-joints at around 25k
Old Nov 13, 2007 | 08:54 PM
TEXASPOWER's Avatar
carrier bearing in the 06s suk for some reason, i went through like 6 and evry one i know has went though some
Old Nov 14, 2007 | 08:11 AM
Was this covered under warranty?
Old Dec 31, 2007 | 04:32 PM
dieselburner's Avatar
My '06 needed it's second center u-joint at 105K, the first one was under warranty and it got a new drive shaft. Second time I paid for it and I took it to a local shop who replaced the AAM designed shaft u-joint and rebalanced the shafts. No issues so far (though it's only been about 6K or so since then).
Old Dec 31, 2007 | 09:23 PM
Installed my lift, new tires and rims = no more vibe. My guess would be mine was tire related.
Old Dec 31, 2007 | 09:41 PM
2001shrtbedcummins's Avatar
might have had a slightly bent rim
