gear question
Old Nov 29, 2010 | 07:41 PM
Jeff M's Avatar
Default gear question
Ok, this may be a dumb question... But here goes. My glove box says my gears are 3.55, however when i am on the highway I am taching 2k to make 70mph. i have 285/75r16's with the auto trans. I used this website:http://www.f-body.org/gears/ to calculate my gears and it seems to me I have 4.10's. Is this weird?
Old Nov 29, 2010 | 08:21 PM
01ctd's Avatar
Mine @ 67MPH right on 2000RPM running 305/70/16 and 4.11 gears. the speed i tested with two different GPS.
Old Nov 29, 2010 | 08:56 PM
GuyWithA24Valve's Avatar
My truck has 3.55s and i'm at 2k right at 70 mph. I have an NV5600
And I have 285/75r16 Goodyear Wrangler silent armors
Old Nov 29, 2010 | 09:02 PM
01ctd's Avatar
The auto have .69 OD vs .73 6th OD. So auto have slightly lower rpm @ same speed than manual on same gears and tire size.
Old Nov 29, 2010 | 09:16 PM
Jeff M's Avatar
So i guess my glove box tag could be wrong?
Old Nov 29, 2010 | 09:17 PM
12valvecumminspower's Avatar
i run 2300 rpm going 65 mph with 265/75r16s, and i have 4.10s. I have the nv4500 5 spd
Old Nov 29, 2010 | 09:40 PM
Jeff M's Avatar
Is that in fifth gear? according to the chart you should be running 71 at that rpm
Old Nov 29, 2010 | 09:58 PM
01ctd's Avatar
check your speed with a GPS. Since you have bigger tires you need to calibrate for the difference in tire size, 31" stock tires vs 33" tires.
Old Nov 29, 2010 | 10:12 PM
yes that is in 5th gear, and i should put my gps in there just too see where my spedometer is reading
Old Nov 29, 2010 | 10:13 PM
01ctd's Avatar
the chart shows 71mph running 3.54 gear, with 4.11 should be 62mph +- at 2K.
