Oil leaks ???
Old Nov 29, 2010 | 05:54 PM
Moose0199's Avatar
Default Oil leaks ???
I have a 2002 dodge ram 2500 24v and I have a lot of oil leaks on it right now. I am going to pull and reseal the motor after christmas but I want to know if anyone knows if too much boost can cause oil leaks? When my chip is on level 5 I can put out 40psi boost max. Thanks
Old Nov 29, 2010 | 07:25 PM
mxtuner1's Avatar
Shoot there is 100's of trucks on here with more boost and zero leaks, and a few with less and mega leaks. Most of the leaks are the front covers and the turbo drainback gasket on bottom of turbo. They can be fixed without engine pull. From drivers seat right front (passengers side) leak is turbo and further forward near front of engine (usually passenger side too) is the front covers. If at back of the engine- then engine pull might be necessary. Good lk my friend.
Old Nov 29, 2010 | 11:35 PM
Moose0199's Avatar
Thanks for the reply and the oil leaks are from every where possible the front covers the rear main the oil pan and maybe more.......
Old Nov 30, 2010 | 05:37 AM
oudive's Avatar
Moose0199,
If it covers the rear main and the oil pan, it might be coming from the tappet cover. This cover is on the drivers side and is the length of the motor. It has a gasket that over time will fail. Not too hard of a job to replace, just time consuming. I would give it a good cleaning and then then start looking for the leaks. Hope you get'em all.
oudive
Old Nov 30, 2010 | 06:25 AM
crzycummins's Avatar
i hate leaks!
Old Nov 30, 2010 | 11:07 AM
01quadcab's Avatar
have you checked the valve cover gasket because a lot of times it runs down the back of the motor and makes it look like it's coming from the pan.
Old Nov 30, 2010 | 12:35 PM
Moose0199's Avatar
Well the oil is coming out of the peep hole between the trans and the motor so that is what makes me think it is a rear main and while i have the motor out might as well reseal the whole thing.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
