Thermostat
Old Nov 29, 2010 | 01:45 PM
DanS's Avatar
Default Thermostat
Where is the thermostat on the 6.7? Is that the sensor right behind the radiator on the left side just infront of the EGR crossover?
Old Dec 2, 2010 | 05:06 PM
Deleted09's Avatar
Just follow the upper rad hose, it will take you right to the thermostsat housing. It is under the EGR stuff (deleted on my truck), and has a metal heat shield on it, too.
There are 2 sensors on the thermostat housing. The smaller sensor goes to the temp gauge in the dash, and I beleive the other one is a drive pressure sensor. There are 3 small bolts to remove the thermostat housing, 8 mm socket, you can leave the rad hose on, and no gasket is needed, it uses an o-ring type. There should be a new o-ring with your new thermostat, but they are re-usable if in good shape.
Did your stat fail, or do you want a different temperature?
Old Dec 2, 2010 | 07:01 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
deleted09 is right on the money.
Dustin M
May 21, 2015 10:19 PM
Brody Olson
Mar 28, 2015 05:14 PM
klein444
Mar 8, 2015 08:19 AM
mmnot
Mar 2, 2015 07:12 PM
