High idle with E-brake
Old Nov 29, 2010 | 01:25 PM
CoalTrain99's Avatar
Default High idle with E-brake
Okay so i started my truck this morning turned the high idle on and my exhaust brake, it sounded like a jet ive never heard it do it before, ever since that one time its not made that sound anymore?? is something wrong..i want that sound back!!
Old Nov 29, 2010 | 06:12 PM
dodgeram082500's Avatar
Early cold morning mine used to do it all the time crank it high idle it and turn the eb on and you got it
Old Nov 29, 2010 | 07:37 PM
ETXBlueRam's Avatar
Some of that has to do with intake temp and ambient temperature. Above 60 something degrees at the intake air temp sensor, the exhaust brake won't always come on for high idle. Let it get cold and it will howl like an F-4 on the tarmac...especially with 5" straight pipe.
Old Dec 2, 2010 | 05:32 PM
beerlvr's Avatar
how do you turn on the high idle?
Old Dec 2, 2010 | 06:36 PM
barkrulz's Avatar
mine makes the same noise when it's cold and the exbrake is on, but doesn't always go into high idle. first time freaked me out. but after the brake actuated a few times (or temp was high enough) it stopped.
Old Dec 3, 2010 | 02:36 PM
to turn on high idle you use your cruise control..turn it on then push set..if you push accelerate it lets it go up to 1500 i think
Old Dec 16, 2010 | 11:02 PM
jdog78's Avatar
u have to push set twice for it to get into mode.i do it in the morn.just to **** the neighbor off about 5 or 6.
Old Dec 16, 2010 | 11:09 PM
99stackedpowerstroke's Avatar
wait on stock truck with just a chip this work??? what do you have to push twice?
Old Dec 16, 2010 | 11:16 PM
jdog78's Avatar
my truck is all the way stock.push cruise on then set twice and it will come off idle then u can run it up with the accel. button.got delete kit and a edge progammer,but waiting to change clutch before i put anything on.
Old Dec 16, 2010 | 11:19 PM
does this work for every dodge?
