Service 4wd Light
Old Nov 28, 2010 | 05:34 PM
dmaxtothemax's Avatar
Default Service 4wd Light
I have an 01 2500HD 4wd... My Service 4WD light came on the other day, it stayed on for a couple days then went out... The selector switch stopped working and i am now limited to 2wd... I put a new switch in the dash and still no luck... I have an actuator on order and awaiting that... Any suggestions or other experiences???
Old Nov 30, 2010 | 12:45 PM
04SVT-L's Avatar
what else do you have on order? the actuator in the front diff or the encoder motor in the transfer case?
Old Nov 30, 2010 | 06:29 PM
The actuator is on order... What is the encoder motor in the transfer case???
Old Nov 30, 2010 | 06:54 PM
Red_Rattler's Avatar
High Tech Redneck
Motor on the t-case is shot
Old Nov 30, 2010 | 07:05 PM
motor on the t-case??? is this another easy fix like the other parts?
Old Dec 1, 2010 | 11:04 AM
Rttoys's Avatar
Instead of guessing/replacing everything, how about checking the codes in the TCCM (Transfer Case Control Module) to see what direction to go in.
Old Dec 1, 2010 | 05:37 PM
I've got a SuperChips tuner with code reader, but not sure if that's the same thing needed or not... I'm not throwing any codes on the 4wd with the superchips reader if that helps... Sorry for the ignorance, thus the reason i'm posting...
Old Dec 1, 2010 | 06:26 PM
High Tech Redneck
That will not read that code. To do that you will have to got to the dealer and have them read it and probably charge ya 75 to do it but it will tell you exactly whats going on....
Old Dec 2, 2010 | 09:47 AM
04SVT-L's Avatar
yes u will need to go to a dealer cuz u need the gm tech2 scanner to read dtc's in the in the tccm. that will tell ya exactly wat it is
Old Dec 2, 2010 | 10:16 AM
Rttoys's Avatar
You'll need a little more high tech tool than just a engine code scanner to see these codes. If you have a friend with a Tech2, Snap-on or OTC scanner they will be able to check it out. You might be able to go Vato-zone and see if they can access the codes, but I don't know if they can or can't.
