Big Oil leak/ Tappet cover
Old Nov 27, 2010 | 11:16 AM
DieselDan98's Avatar
Default Big Oil leak/ Tappet cover
I have a massive oil leak in the front of my motor. Right now I am doing the KDP repair and everything looks like it should. I did notice my plastic tappet cover is warped real bad and prob is leaking from there. Why is it plastic and why did it warp? Also did they make 2 timing covers for the KDP mine is a raised one. Do I still tab it?
Anything else I should do when I tare apart half of the motor?
Old Nov 27, 2010 | 12:47 PM
angelic0-'s Avatar
set timing to 15-16,5°
Old Nov 27, 2010 | 05:43 PM
I ended up braking the cheesey cover, I was thinking about one from PDP. Did Blow-by warp my OEM one?
Old Nov 27, 2010 | 06:56 PM
FastCR's Avatar
that billet one is sweet if you have the coin.
I'd make sure your not leaking from the vacuum pump/power steering pump while your in there.
Old Nov 27, 2010 | 08:26 PM
Red_Rattler's Avatar
High Tech Redneck
Shouldnt be plastic... Mine and every other one ive seen is tin... and Im lost as to what u mean by raised one? the kdp is inside of the timing cover... More info or a pic of what u have goin on would be great
Old Nov 28, 2010 | 04:30 PM
My timing cover is aluminum and the newer design I guess because it is a 98. The normal KDP tab will not work. I need to bend it like a Z shape. I was a little confused on the tappet cover. the outside had insulation on it and that is what looks warped. I am going to make my own tap put timing cover on it run it with out acc. on and find the leak. And be done with it. Thanks for the replies.
Old Nov 28, 2010 | 04:34 PM
joshmock's Avatar
if the kdp pin is not flush with the surrounding metal, it needs to be pushed back in and then tabbed.
Old Nov 28, 2010 | 05:47 PM
my timing cover looks like the one in post number 4 in link below. Not flush the PO peened(sp) it over
Cummins Turbo Diesel-Scout II Swap - Binder Bench
Old Nov 29, 2010 | 07:05 PM
*******Found it. The stud and nut that holds on the IP backed out and is pissing oil out the hole. Thank god its an easy fix. Now time to fix the rest of my broken junk
Old Nov 30, 2010 | 04:49 AM
angelic0-'s Avatar
set timing to 15-16,5°, you wont regret it
cummins Pride
Sep 28, 2015 12:11 PM
Gomerpile79
Apr 9, 2015 03:45 PM
pro graphic solutions
Feb 10, 2015 03:48 PM
Ryans71
Jan 14, 2015 07:52 PM
ash23k
Dec 30, 2014 08:31 PM
